Lifting Carpet Lining
PaulCall
Hi all, anyone know how to lift a section of carpet lining without destroying it?
I want to fit a rear dash cam/ reversing camera and the feed/ video signal cable needs to be fed up the D pillar and then down the roof under (over?) The head lining to the front. However with the exception of the rear door cable entry glands and the rear light cluster (barn doors) I do not have access to d pillar / roof cut Outs. The Van was professionally converted and the D pillar and roof are carpet lined.
Have you managed to get this sorted? Also i had mine installed by GZR Performance as they were recommended by VW Breeze.
Sorry I've not answered your question.
I've done several vans for friends, from my experience I don't think it will pull away without tearing or stretching as the glue is pretty strong stuff also lining carpet is very fibrous so strands will separate/ tear if you know what I mean. Only one way of finding out! Easily replaced if damaged though
Thanks for the info, I have not been brave enough to tackle it as yet. But will get to it over the winter.
Hi - did you manage to sort this? I have the same issue - fully carpeted. I've used an endoscope and am happy getting from B pillar to the rear near the D-pillar but can't see how to get into the d-pillar form the the top and down to the rear lights. I've tried up from the riear light aperture too and can't fond an easy route up and over to under the roof. I think I'm close form the imagery I've managed to see but it's difficult to get navigate round the 90 degree turn at the top!
