elbandito57
Hi all,
I have a T6 LWB Kombi which has 8 lashing rings as standard. I want to remove the 4 rings in the middle of the van which looks easy enough with a spline socket. Then I'm going to make a frame for transporting MX bikes and fix this frame in place using the original 4 holes that I removed the lashing rings from. I'm guessing on the underside of the flooring bed on the chassis rails there is a fixed nut that these screw into? Can anyone confirm this? And also confirm if the thread is normal or if I will have to find the specific thread for my replacement bolts.
Thanks in advance!
Thanks in advance!
