Lower control arms T5 to T6
Yogi_72
Hi all,
Can someone confirm with me, are the front lower control arms for a T5 the same as those on a T6?
It’s cheaper to replace the whole control arm (here in Aus) than to replace the front and rear bushes separately.
Thanks in advance
They do look different but the end result should be the same . I think there might be a mounting hole for the LED light sensor on the newer ones but i cant see why it wouldnt work if you didn't have LED lights . If you can get the arms for a T32 they usually have stronger bushes in them
