Lowered suspension now fault code
jimdad
I had t6.1 suspension fitted to my t6 rac van today and it's lowered it a fair bit
Driving home I had some fault codes
Come up.I've cleared all but one.
Does this mean I need the tracking doing due to being lower .thanks
No It isn’t the tracking , Won’t hurt to check the tracking however. , it will be something like the abs sensor isn’t plugged in properly . The abs light normally comes on with the stability control warning. intrigued that you say it lowered the van. normally the T6,1 shocks and springs lift the van. Did you only fit. Shocks. This will lower it by 20 mm
It had shocks and springs changed its lowered it by about 50mm.
Perhaps they were sportline ones.
I was wondering if it could be due to the wheels been cambered differently now
Definitely nothing to do with alignment ,!
Must be sportline or similar. The T6.1 is 10 mm higher standard
Got 2 codes up today one to do with ignition and other steering column actuator. The steering wheel wasn't quite central when I bought it so I'm wondering if it's been off
If you value your tyres i would get an allignment check done.
I had my suspension upgraded and all appeared correct but my front tyres had completely worn through on inner edge and needed changing.
All done.and codes reset
