MAF sensor reading on T6 CXGB 85k
samuelpovey123
Hi, I’ve just plugged a reader in to suss slightly high fuel mpg and noticed the MAF reading at idle at temperature was reading between 8.6 and 9. Is this a normal reading or should I look into it?
Normal, assuming it's expressed as grams/second.
If staring the MFD reading only please note the MFD smooths readings by spreading out the fuel used by DPF regeneration over longer period - thus showing skewed numbers for quite some time after the DPF regeneration.
