Hi all, I have bought a T5.1 caravelle with a faulty auto gearbox. It is a 7 speed DQ500 and I am getting fault code 10793 - Transmission input speed (G182)
P0716 - Implausible signal.
The gearbox is in limp mode and will only select reverse and even number gears
I sent the mechatronics to ECU testing but they do not have the software to test it.
Another company said to change the speed sensor but I would have expected the garage it went to already to have done that
Anyone had this fault or has a DQ500 mechatronics repaired?
Thanks.
Thanks.
