I’ve not bought them yet, but I’m looking at the 18” amorak steels… quite like the idea of those ageing then put the originals back in a few years back to stock alloysWhat's the width of the wheels?
Mine are 265/45 R20 and they just fit under Floyd’s arches fully aired out.255 might be a shade wide. @Texxaco - you’re on air, what’s your view?
YepSo plenty of room for 18s on 255 45 ?
Thank you.
Are you looking at standard Amarok steels, or looking at having them banded??I’ve not bought them yet, but I’m looking at the 18” amorak steels… quite like the idea of those ageing then put the originals back in a few years back to stock alloys
Not sure I want to do that unless 255 is going to look silly on them?Are you looking at standard Amarok steels, or looking at having them banded??
I only ask because the standard rim is 7.5” wide…. not wide enough for the 255 really. 235 is as wide as you want to go on that rim. If you’re going banded then anything from 8.5” will accommodate the 255 ok.Not sure I want to do that unless 255 is going to look silly on them?
Thanks, that’s why I was asking the question really - any idea what would be a good option? As I said been impressed so far with the vectors and reason for those is good wet/winter grip, plus camping if it gets messy and general wear rate… so it’s either find 235s or have the steels banded…I only ask because the standard rim is 7.5” wide…. not wide enough for the 255 really. 235 is as wide as you want to go on that rim. If you’re going banded then anything from 8.5” will accommodate the 255 ok.![]()
Look like they are to me.
The best looking steel wheel imo.
Definitely.
To be officially load rated yes…. the CC 2’s come in a 104Looks like I’d be better with 235 but on the cross climates I’d have to go up to a 55 to get the load rated 104 suv - is that correct?
