A bit of a long shot. New aftermarket head unit going in ASAP (Pioneer AVH-Z9200DAB) and trying to strip out/tidy what's already there.
I have an aftermarket reverse camera with one of those screens that attach over the rear view mirror. The headunit will replace the current screen. I've traced most of the wiring and understand it to a large degree and can see mostly see what I have to do. Two aspects have me a little stumped.
1. This bit I don't get at all – on a relay terminal I have a green "trigger" wire going to the screen unit (self explanatory) but also from the same terminal, a red (presumably +12v) wire going into the phono plug along with the camera feed. The camera itself seems only to have a single black cable into it. Can any explain this to me please?
2. @Absolut5 I have a pink wire that looks to go to beneath the passenger seat (yet to see exactly where) which I expect is wired into the reverse light circuit and is used as a signal to switch on camera/screen. Does this need to go direct to the headunit's Reverse Gear Signal Input, or does the interface to retain the parking sensor display you supplied take care of this too?
