Missing Torx screw from glovebox
Andyvanman
Hi all
I was just installing my new glove box light but found that the metal part on the rear glove box where you would connect th Earth didn’t have the Torx screw i needed. The VW converters had already installed the Van X upper glove box and looked like they couldnt be bothered to replace the screw. Does anyone know what size it is and where I can get one from please?
There is no separate earth on the glovebox light, it’s part of the courtesy light loom. There will be a few brown earth wires going through the coloured connectors behind the glove box. You could pick an earth up there.
Thanks so is it ok to connect to those instead ?
Definitely. The courtesy circuit goes through those connectors. Use red/black +ve and brown -ve
Resurrecting this thread because I removed my glovebox a couple of weeks ago and went to refit it today but I can't remember where I put the screws. Is there a part number for these?
Thanks but that listing has various options so none the wiser here.
I guess if I knew the length and width I need that would help.
