L Lee540 Senior Member T6 Guru 30 Jan 2024 #1 Does anyone know if I can enable cruise using carista once I fit the stalk? I have the right wires for it all to work just wondering if I can do it all DIY without VCDS..
A airhoguk Senior Member T6 Guru 30 Jan 2024 #2 Carista won’t be able to do it I’m afraid, only good for resets, diagnostics and altering factory settings such as window closing, folding mirrors,etc
M middle-englander Senior Member T6 Guru 31 Jan 2024 #3 I think ODB Eleven though can from reading the mammoth thread on this subject.
Craig. Craig VIP Member T6 Pro 31 Jan 2024 #4 Lee540 said: Does anyone know if I can enable cruise using carista once I fit the stalk? I have the right wires for it all to work just wondering if I can do it all DIY without VCDS.. Click to expand... You need to check which Steering Wheel control module you have as not all of them can have cruise control activated. If carista can do long coding then yes, it can activate Cruise but VCDS can do this for sure. Last edited: 31 Jan 2024
L Lee540 Senior Member T6 Guru 31 Jan 2024 #5 Craig. said: You need to check which control module you have as not all of them can have cruise control activated. If carista can do long coding then yes, it can activate Cruise but VCDS can do this for sure. Click to expand... Module is fine. I think I will just fit it all in and get someone local to make the adaptation. Cheers.
