Sold Motexion glass bulkhead BRAND NEW for single side door.
Lightrofit
Electrical and Retrofit Mobile Specialist
VCDS User
Hi folks.
I have a brand new Motexion glass/window bulkhead for sale.
Never been fitted (or removed from the box!) and is immaculate.
Bought it last year during lockdown but now my van plans have changed and is no longer required.
looking for £300ono
located in the Caerphilly valley, just north of Cardiff, South Wales.
Hi mate, would you know if this fits a T6.1 PV single slider lwb?
Hiya Ricardo T,
There is absolutely no reason why it shouldn’t. This bulkhead is designed to fit the core shape of the interior and from what I have seen, that hasn’t changed to I’d confidently say yes.
It’s aimed at vans that didn’t have a bulkhead from factory so if yours does have the steel bulkhead then the brackets will need to be removed first.
Just also checking that it's not steel? Willing to post? Would you take £250 if so?
Ok. Interested but the distance may kill it. Ill put a post on the Forum collection/delivery assistance to see if there is any help available.
No worries bud,
I didn’t address the offer as it was conditional on being willing to post, feel free to send a PM to discuss
Great thanks. I have a 2017 LWB T6 panel van having the steel bulkhead removed, edges grinded down etc. before fitting removable rear seats. Looking for bulkhead for when van is used as a van, that can then be removed for holidays when rear seats go back in.
Based on that, would this one fit? Also looking for bulkhead for behind rear passengers
I get what your idea is. Personally, I think it would be a lot of faff to remove it periodically due to how it’s installed in the van.
You’re better off using the steel bulkhead for your idea as it just bolts in and out with minimum stress
When you say periodically, it'll be twice, maybe three times a year. As far as I know, the steel bulkhead and it's fittings can't be left in place if fitting rear seats. It'll all need to be angle grinder out. I'll call the conversion company and have a chat though.
The issue with that is the way the Motexion bulkhead it attached to the shell, the screw holes will wear with repeated removals and eventually become unusable.
Just something worth considering.
