Moving seat back on base to get more leg room
Caulkhead
Builder
Has anyone either moved or know how to move the front drivers seat for more leg room, as I’ve got really long legs I can drive the van ok but would be better with more room.
I am 6'3" and the only way I was able to achieve more legroom is to lift seat all the way up via jacking mechanism, put seat back little bit more upright and push it as far back as possible. In my case removing bulkhead isn't an option but that is an alternative as you would be able to move seat further back with OEM set up and be able to recline it swell as lower it for that "cool" look.
I'm 6ft 7" and have just about enough room to drive a manual Kombi, do the panel vans have less room due to the bulkhead?
I doubt there's much you can do as it comes from the factory, there maybe a fabricator who could make some longer runners or move the existing ones, but I'd worry about warranty and crash worthiness.
