@Deaky or @Pauly, do you know if the airbag from a plastic T6 steering wheel would go into this? I'm working on the assumption that if I bought it I'd need a new wiring harness and the repair leads as well as someone with vcds. Is there something about a different spigot ring as well? Cheers in advance.
Im going to defer on this one as im not actually sure, coding in CC from wheel buttons is not the same as adding a standard MFSW (and also dependant on what setup/stalks you already have)
The only person i know that has successfully done a euro6 style cruise upgrade is @MAT@VWT5UPGRADES
