Cool good work does GTI one take T6 switches airbag is differentI did the exact same job with the MK7 Golf wheel, but mine had flappy paddles, and it was just as easy to carry out, and pretty much plug and play once you've swapped the switch gear over like above.
Does that mean that the polo buttons would work on a transporter wheel in a t6 ?just a tip for you guys.....the polo uses the same can system so you can convert a mk7 gti wheel by buying the pods from tps and swapping over .
There's another good thread on here about fitting various different VW wheels to T6's, I'm at work and can't find the link right now.
But, yes the Polo wheel works straight out of the box on a T6 I believe, it's the ACC where things get tricky and I can't remember if the Polo ACC works on a T6 (the Golf doesn't, but can me made to)
Just bought this as I got a good deal (I think), I don’t have ACC or DSG so should be a straight swap as all the buttons are the same. The only thing I’ve noticed is to small holes which what look like snapped screws in but I don’t think it will effect the wheel?
Am I right or have just waisted a load of cash?
As all the buttons match what you have, i dont see why that should not work fine. Drop it on and see
I have a similar wheel with the holes in the back but mine have no metal in them just empty
