New battery help
lukethompson86
T6.1 owner and all round VW enthusiast
Hi all
Really
Could do with a new battery for the van, VW have quoted me a little over £450 fitted.
Most certainly have the capabilities of changing one myself but they have advised it needs ‘coding’
2021 T6.1 T30 with start / stop
Can anyone advise if this is correct or they will self learn once in?
Also if anyone could recommend a decent link to a battery itself.
Thanks in advance
Yes, so it knows it’s got a new battery but they do self learn apparently- a Carista is always handy to have to read faults
Wow, that's like £300 to code a £150 battery. Where do they get these prices from?
It's not imperative that you code it. The van will eventually 'learn' the new battery apparently.
But as above, buy a carista or find someone nearby with VCDS who will do it for you.
Hi all
Really
Thanks in advance
The band of brothers and sisters that the forum consists of, if you put out a request for someone to locally code it for you, you would be inundated with a chorus of 'pop it round to me, I'll sort it for you', just take a nice bottle of Rioja (for me) or the members choice of beer and your wish will be granted. It's so easy to do with a Carista, OBD or VCDS. We are well worth the membership fee! It's good to have the job done properly.
I bought this a few weeks ago - straight swap. I have VCDS so coded the battery as per the many helpful posts on the forum, but as above, I believe the van learns it has a new battery
Thank you mate , I’ll have a look later on into this link. Was the battery the same size , dimension wise I mean as opposed to capacity obviously ,
Ta
Hiya mate
Just about to order this battery , the retailer was telling me it was slightly longer than the current which I expected .
You said it fitted ok though right ?
Thank you
Hiya mate
Thank you
Yep - fitted no problems. If you search the forum, you’ll see many have fitted it and a few have fitted the even larger A13, which is a bit of a squeeze apparently
