Something very odd happened last night.....I unlocked this amazing new feature that allows to you turn on the right indicator by putting the handbrake on!!
The right indicator on my T6 would not go off when moving the stalk back to the centre (left worked fine in left position) so every time I locked the vehicle with the indicator stalk in the centre position the right-hand parking lights would come on - obvs not good as it would then drain the battery. After a bit of messing around trying to figure out how to make it stop from indicating right when in the centre position I found that if I release the handbrake the indicator turns off
Anyway, has this happened to anyone else before? Luckily I was on flat ground and had to leave it parked without the handbrake on in order to save the battery!
