I bought my new VW Transporter T6.1 kombi from an official VW dealer 12 days ago. It ran only 480 km, and the yellow exhaust system fault light is on.
Has anyone experienced such an issue with a new car?
The problem was solved by changing the NOx sensor by VW certified technician. After a while, the problem appeared again. The OBD scanner shows 3 faults:
P23AD, 608780, 37993.
Details:
P23AD -
Freeze frame :
Calculated load: 0 %
Coolant temperature: 85 °C
Engine rpm: 1670 RPM
Vehicle speed: 52 km/h
Intake air temperature: 10 °C
Air mass value: 16.22 g/s
Absolute throttle position: 24 %
Time since engine start: 2217 sec.
Commanded EGR: 0 %
EGR error: -49.82 %
Fuel level input: 24 %
Ambient air pressure: 100 kPa
Battery voltage as seen by the engine ECU: 14.80 V
Relative throttle position: 14 %
Outside temperature: 9 °C
Absolute throttle position D: 15 %
Absolute throttle position E: 15 %
Commanded throttle actuator position: 14 %
Engine oil temperature: 86 °C
Accelerator pedal position sensor: 0 %
Engine torque: 0 %
Engine reference torque: 250 Nm
608780 -
Freeze frame :
Priority: 4
Malfunction frequency counter: 3
Unlearning counter: 75
Odometer reading: 934 km
Date: 26 Mar 2023 08:22:43 PM
Terminal 15 status: off
Terminal 50 status: off
Voltage: 0.8 V
Outside temperature: -50.0 °C
Status Bremslichtschalter (HW): on
Status Bremslichtschalter (CAN): off
off: not operated
Position lamps: not operated
Automatic high beam assist: not operated
Low beam: not operated
Parking light left: not operated
Parking light right: not operated
Stoerschutzzaehler: 5.0
Terminal 15 status: on
Status Bremslichtschalter (CAN): on
37993 -
Freeze frame :
Priority: 2
Unlearning counter: 40
Odometer reading: 890 km
Date: 26 Mar 2023 11:05:09 AM
Engine rpm: 1670.00 RPM
Normed load value: 0.0 %
Vehicle speed: 52.0 km/h
Ambient air pressure: 1000 mbar
Voltage terminal 30: 14.800 V
