Pete24
Hi, bit new to all this camper stuff and already getting stuck into various odd jobs around our new camper. I have a few questions regarding pop top maintenance.... I have done a bit of reading but not found answers to everything, so I thought I'd start a thread.
Wind deflector - we have the typical rubber profile strip along the top of windscreen, but it is coming away at both ends. Looks like it could do with replacing as opposed to re-bonding. Where might be the best place to source the correct replacement? Is there anything else people use which is more durable (e.g. plastic)? The current rubber strip is only 4 years old.
Roof sealing - I have noticed that, no matter how hard I strap the roof down, I'm left with a 2-3mm gap (at it's widest) along the passenger side between poptop roof seal and van roof. The gap is widest in the middle, and it doesn't take a lot of force with the hand on top of the roof to close the gap. The roof is definitely clear of the canvas or any other obstructions; it is like the GRP has warped slightly over time. Is this something to be concerned about? I notice there is a large drainage channel just inboard of the seal.... If it is, how could I go about fixing?
Roof seal maintenance - do people treat the rubber seal with anything to prolong longevity/sealing?
Scissor hinge - I have read that these need regular inspection and that the fixings can sometimes work loose over time, so I got the step ladder out with spanners in hand to set about checking. It then occurred to me, you can probably over-tighten these fixings - am I right? If so, any guidance on how tight they should be? Also, what do people use to lubricate the hinge and nylon bushes?
Thanks in advance
Thanks in advance
