Hello guys
I've followed the forum advice and run a scan on my T6, apart from the airbag error, (which is of my own making) I have 5 engine warnings.
Are the fuel related ones because the engine isn't running?
The MAF sensor is listed an 'intermittent' and the barometric sensor as 'malfunction'.
Anything to worry about? I have a few months left on my dealer warranty so now would be the time to bring this to their attention.
5 Faults Found:
5196 - Relay for Fuel Pump 2 (J49)
P2632 00 [032] - Open Circuit
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 100229 km
Date: 2000.00.00
Time: 00:00:00
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 13 °C
Intake air temperature: 15 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 12.320 V
Unlearning counter according OBD: 4
Engine status: COENG_STANDBY
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 0
5199 - Relay for Fuel Pump 2 (J49)
P2633 00 [032] - Short to Ground
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 100229 km
Date: 2000.00.00
Time: 00:00:00
5200 - Fuel Pump Relay Control Circuit
P0627 00 [032] - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 100229 km
Date: 2000.00.00
Time: 00:00:00
Intake air temperature: 14 °C
10065 - Mass Air Flow Sensor (G70)
P0104 00 [032] - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 100229 km
Date: 2000.00.00
Time: 00:00:00
Coolant temperature: 12 °C
Voltage terminal 30: 11.340 V
Air mass: actual value (mg/stroke): 0.0 mg/stroke
Standardized airflow ratio: filtered: 3.9988
EGR Solen.val.: actual value: 99.22 %
Throttle valve adapter: actual value: 103.94 %
Charge air pressure specified value: 1050 hPa
Charge air pressure: actual value: 1005.4 hPa
Mean injection quantity: 0.00 mg/stroke
9531 - Manifold / Barometric Pressure Sensor (G71) / (F96)
P0105 00 [032] - Malfunction
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 100229 km
Date: 2000.00.00
Time: 00:00:00
Voltage terminal 30: 11.360 V
Charge air pressure: actual value: 1011.8 hPa
Intake air pressure sensor after air cleaner: raw value: 1150 hPa
Engine status: COENG_READY
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 1
5 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 100229 km
Date: 2000.00.00
Time: 00:00:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 100229 km
Date: 2000.00.00
Time: 00:00:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 100229 km
Date: 2000.00.00
Time: 00:00:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 100229 km
Date: 2000.00.00
Time: 00:00:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 100229 km
Date: 2000.00.00
Time: 00:00:00
