Vdubster
HI all im hoping some one can help as I have exhausted myself with this one.
Basically My reverse lights have stopped working, after the conversion it appears and after my last mot ( only recently realised they wasn't working with failing its new mot )
1 - No power at rear reverse lights ( using led lights all round and all others work perfect, literally only reverse lights )
2 - No power at Green connection under passenger seats ( which im glad as this hopefully means I didnt or haven't trapped a wire in the back )
3 - fuse 10 is it? that works fine and double checked ( fuse box in front of battery ) so power to the fuse and power from this point onwards
4 - no knuckles later and some serious bending through the engine I managed to disconnect the connector from the reverse light switch on the gearbox/engine, tried to short it with it in reverse ignition off and on, lights on and off, got absolutely nothing reverse light wise.... couldn't quite get to the electrical switch with the volt meter to test so in not sure if there is power there or not.
5 - put the switch on a new reverse switch I bought, pressed the button in, absolutely nothing, so I feel its not a faulty reverse switch...althought cannot be 100% sure.
6 - it seems I have no power in between the reverse ignition switch and the from what my crap understanding of electrics is the j519 onboard supply unit? im sure I've eliminated everything else.
7 - I've come to the conclusion its either a trapped wired or bent pin between the reverse switch and the j519 unit or the j519 onboard unit its self? would I be correct in these assumptions?
The only strange thing about this is that about 6 months ago my rear van doors went crazy constantly beeping, vw installed a new wire for this, I get the funny feeling that new wire starts and comes from the same place I think my reverse light wire does the j519 onboard supply unit which im lead to believe is around the driver lower dash area? have they knocked a pin or cable or etc? or im I completely wrong on this? im a complete novice and its taken hours of reading to get this far, any input advice or expertise would be be really appreciated at this point.
This has caused me more hassle than the entire first time van conversion! I have no idea if there is anything obvious or incorrect I am or aren't doing. thanks again!
