Hi there , I have a 2016 vw t6 highline which the brake lights have just stopped working, both rear lights and high levels, I have replaced the brake switch on the master cylinder, checked the brake switch fuse sb16 and have also checked the turn and brake light fuse sc47 , I seem to be getting power at the midway plug under the passenger seat for all other lights ,but not the brake light terminal. I also disconnect the battery for 5mins after new switch was fitted in case an ecu reset was need, sorry for the long post just giving as much info as possible, any info will be greatly appreciated.
