No central locking
JB_T6
Hi,
After long search for a van I found one that ticked a lot of boxes but in the proces I didn’t see that the van has no central locking. So I have to unlock each door individually. I was not expecting that from a 2019 model. But since everything else was good I bought it anyway.
After searching around I haven’t found any aftermarket solution for un upgrade. Has anyone have any idea or solution? Thanks.
JB
You sure it has no central locking is there no buttons on the keys we've never seen one without it even on a builders spec van?
I was as surprised as you. There is a lock on every door handle. And just “ordinary” key.
I got an ordinary key with my Startline - called a surf key.
Does turning one of the locks unlock all the doors? Are there a lock / unlock buttons on the inside top of the drivers door?
None of the above :)
Each door is opened individually and no buttons on the control unit for windows and mirrors.
Possibly a special order - can you get a build sheet for the van - from your dealer or below
What about electric windows in driver and passenger doors?
If you get a chance a VCDS Scan would be interesting to have a peek - to see if the central electronics controller possibly has components of central locking.
Not a VIP member, I can’t access this build sheet codes.
It has electric windows and electric heated mirrors.
I will ask around for the VCDS scan.
Reactions: mmi
Post a photo of the drivers door window buttons.
