ok. . . . its the end of another day at work and time to check-in on the charger. . .
its still in storage mode . .
its still delivering around 3A that is running the load (pump)
and the voltage has been constant . . . not cycling like the NOCO was doing.
it seems that the Victron will run run like this for ever . . ?
so its time to upset the flow. . . at what point will it restart its cycle?
well lets see.
i decided to add some more load. . . i plugged in a dehumidifier in (on fan only mode).
this took the load up to 7.5A - half the rated 15A of the charger . .
but the charger sat there very happy . . . still in storage mode . . .
so now i threw the big guns at it . . . i switched on the compressor side of the dehumidifier on.. .
The inverter started beeping the overload warning . . . the compressor spooled up.
we were now pulling the full 15A from the charger . . .
which now caused the battery voltage to drop slightly due to the current flow . . down to around 11.9v under load.
at this point the charger moved over to bulk mode and started a new charge cycle . . . . back to 14.6v bulk charge.
you can see the change here . . .
and here:
so there we go . .
we have the data.
the Victron works much better at Charging + running Loads than the NOCO.
