Sold Noco Genius multifunction charger G15000 EU 12V/ 24V 15A for lead-acid and lithium batteries
Dellmassive
VCDS User
Moderator
T6 Master
VGC, been kept in the office mostly, so nice clean condition.
a decent 8stage 15A smart charger for SLA and Lithium.
plus Power Supply mode 13.6v @5A.
with Jump Charge -
"Similar to the Engine Start feature on
traditional chargers, but places less stress on
the battery. It uses a combination of high
voltage (16-17 Volts) and current (20A for
G15000 and 30A for G26000) to rapidly refill
a dead battery"
£70 collected or plus postage.
Noco Genius charger G15000 12/24V 15A for lead and lithium batteries​
The Noco Genius G15000 is a universal charger for 12V/ 24V lead and 12V lithium ion batteries in cars, trucks, tractors, boats, motorhomes and many more. up to 400Ah (12V) or 200Ah (24V).
The charger has a special repair program for restoring, repairing and storing old, unused, sulphated or acid-coated 12V batteries. With the supply mode, the Noco Genius G15000 can be used as a DC power supply for DC 12V on-board devices. The additional Jump Charge function is specially designed for reviving discharged 12V starter batteries. This mode is fundamentally different from other chargers with a jump start function. The Jump Charge mode has a charge control regulator to avoid overcharging the starter battery.
The charger has two connection options: Crocodile clips and cable lugs. To use the cable lugs, they must be detached from the crocodile clip.
Properties:
  • 8-stage charging program
  • suitable for 12V & 24V acid- gel, calcium, AGM, start-stop batteries and 12V lithium batteries
  • actively monitors the battery for safe and efficient charging
  • ideal for batteries between 50Ah and 400Ah (12V), 25Ah and 200Ah with 24V batteries<- suitable for 12V & 24V acid- gel, calcium, AGM, start-stop batteries and 12V lithium batteries
  • Repair program for regeneration of batteries
  • Jump Charge mode for resuscitation of 12V starter batteries
  • usable as DC power supply for 12V DC devices
  • spark-safe technology and reverse polarity protection
  • technical data:
  • Voltage: 12V, 24V
Charge voltage:
  • 14.5V (12V normal, batteries 50-400Ah)
  • 14.8V (12V cold/AGM 50-400Ah)
  • 29.0V (24V batteries 25-200Ah)
  • 29.6V (24V cold/AGM 25-200Ah)
  • 14.2V (Lithium 14-400Ah)
  • 16.5V (Repair function for 12V batteries, 1.5A)
  • 15.5V (Supply mode 5A)
  • Battery capacity: 50Ah to 400Ah (12V), 25-200Ah (24V)
  • Current: 15A (12V), 7.5A (24V)
  • Insulation class: IP44
  • Connections: Crocodile clips/cable lug
  • Alternative to MXS 10, Ctek MXT 14.0, Ctek XT 1400, Ctek Lithium XS
Brand:NOCO
Compatible Batteries:Flooded, AGM, Gel, Calcium, Lithium
IP (Ingress Protection) rating:
MPN:G15000 EU 12V/ 24V 15A
Charger Amps:15A
Charging Range:50 - 400Ah, 25 - 200Ah
Output Voltage:12 - 24V, 12/24
Input voltage:120-240V DC
IP (Ingress Protection) rating: :IP44 (splash-proof)
Warranty:5 Years
actual pics
1707377785738.png1707377825385.png1707377911321.png1707377893437.png1707377882577.png1707377853003.png1707377814830.png1707377805643.png1707377795573.png
user guide:
