Hi all, after a bit of advice regarding a noisy fan - the hot/cold air blower for the cab interior.
When turning the fan on it is normal volume for about three or four minutes but then I get a constant and fairly loud noise, almost as if there are a load of dried leaves in the ducts.
If I switch the fan off and straight back on I get another three to four minutes of almost silent running (in speed one anyway, the other speeds are noisier as you’d expect) then it starts getting noisy again.
If I don’t turn it off/on the noise will stop after about ten/fifteen minutes…only to restart three to four minutes later!
I have had the pollen filter out several times and tried vacuuming the opening. I’ve changed the filter too. I’ve kept an eye on the intake in the plenum chamber and only had to clear the grille of a few leaves once - we don’t have to park under a tree usually.
Is there some obscure place debris could gather and take a while to reach the fan blades and cause noise or is it a bearing in the motor or even some electrical issue?
I checked similar threads but didn’t see an issue like the one I have.
