Ocean stiffer rear, colors
Californication
Hello!
Looking for stiffer rear end on t6 ocean. Currently has two white marks. I have set with one grey mark.
I’ve put on konis but it seems they’re being overpowered by too soft of springs. In the front it’s night and day.
Anti roll bars been delivered. That will take care of lean in the turns.
Thanks!
Hello again! Trying to stuff up the rear but I’ve got a question please. I’ve looked up the spring color chart but it does not answer my question.
The double white mark springs (ocean, presumably t28 or t30) are heavier than the single grey mark (t32).
Am I making the rear softer by swapping to the single grey mark spring? Not what I’m trying to do. Any help is appreciated :)
Hello and thank you for the responses. Immediately after posting this I thought to call steve at CRS since he is mentionned on here so often. Even though i'm not a customer he took his time to explain everything to me. Really really appreciated!!! thank you :)
Explanation: he only uses rear springs with either 3 grey stripes or one red stripe as those will give the desired result.
I put everything back together with original springs.
i have the same problem. ocean with 2 white marks. can't source any. did you fit the t32 ones with the 3 grey paint stripes ? are they stiffer/longer ?
