OEM LED coming home lights not coming on
Texxaco
T6 T32 204 DSG on SoLow 3H Air remapped to 257PS
VCDS User
T6 Legend
Any ideas anyone, have VCDS which shows no errors hence me asking on here as I stumped?
To add I don’t t have the option to turn them off on my MFD.
Hey Andy,
Cheers for this, I didn’t know you could turn the function on/off.
They used to come on with no issues, now they just don’t play ball which is rather annoying
Will check and come back to you.
Pete
Hi Pete. Nor did I, but after just having OEM full LED headlights fitted, I was curious for the answer too.
Hi @Texxaco Could it be that you may have accidentally turned function off?
Just found this from forum owner’s manual;
Andy
You not turning the actual function on and off thats just how they work, they are always available you just need to flash the main beam before exiting vehicle and that will activate the lights for the determined period (30 seconds i think)
Hi @Pauly
I wondered about the setting to turn the option off again.
Makes much more sense now.
I did RTFM, but obviously a little over my tired head?
Thank you
Do you have to flash the main beam everything you exit the van or is this a one time settii in no option @Pauly ?
Thats how you tell the lights to stay on after you take the key out the ignition, so its everytime you want to use the coming home function
I think every vehicle i have had for quite a few years has this function and its the same on all of them
My wife’s Audi Q3 2015 (PQ35) just does coming home automatically without using flasher when it’s dark. I’ve tried to find if there was a coding or adaptation to make T6 work like that but apparently not.
Reactions: mmi
