OEM LED Numberplate light failure.
oneandolli
Hopefully someone can help me please. I have a 2019 T6 Tailgate fitted with OEM LED numberplate lights from factory.
Looking at the rear, left hand side does not light up and no error is showing on the dash or on OBD. If I unplug it the error on dash appears and OBD. If I swap light units over left to right right to left the right hand side still lights up fine, however left still doesnt work with no error messages. I've even bought replacement light units and the issue stays the same on the left hand side.
I'm guessing it's a broken wire somewhere along the maze of wiring, and I'm hoping someone has had a similar issue and can direct me straight to the the cause.
The van is a bare van so access isn't an issue.
I'm technically minded so any help and advice would be appreciated.
