Oil change t6.1
Benji46
Hello friends
I'm planning on doing an oil change for T6.1 2021.
I'd like to know if the onboard computer reminder will stop once oil replacement has taken place or if it will require a reset ?
Just hold the 0.0 button in front of the steering wheel then turn the ignition on (dont start the engine)
Hold it for a couple seconds then let go of the button when it displays reset oil, then press the button again to actually reset it
If you want to reset the inspection interval do the same process again but hold the button for a few seconds longer it will go to oil reset then to inspection reset then let go off the button while inspection is displayed, then press the button again to perform the reset
If you hold it a few seconds longer again it will go to oil then inspection then back to normal
Hi Pauly
Thanks for responding where is the 0.0 button..? I'm not entirely sure..?
Thanks again
