Hi, has anyone had problems shutting side slide windows. On the sliding side door (nearside) it opens ok but is a real struggle to get it to completely shut. The plastic trims above and below the squeeze together door catches don't seem to sit in fully. I can see a spring in the bottom of the bottom trim where the plastic cover is not fully home. Just wondered if anyone has had this trouble? Thanks. (By the way it is a T6, 17 plate highline Kombi model)
