P00AF00 & P256300…..van stopped
Briston
Broke down yesterday, coil light started flashing, loss of power then basically stopped.
Got recovered….. has anyone else had this happen? It seems turbo related,while trying to pin point it
Today,van will eventually start but only run on tick over,any attempt to rev to cuts out & Dpf light has now come on.
Dark now but looking to remove oxygen sensor tomorrow to check for oil, could it be just stuck actuator?
Bri
Bri
Hi mate,
Mine was blocked DPF and a hole in the turbo vacuum hose.
Hose was cheap enough, but getting the DPF removed, cleaned and reinstated, not so much.
Cheers for your input, dpf light came on after it broke down, go figure, still not at bottom of it, think turbo is shot tbh
