Having a little clear out,
Pair of T6 Camper Glass Safari windows, professionally removed however the drain "pipes" (for want of a better description) broke during removal. From what I understand this is inevitable if removing.
Only reason for sale is.... If you want something doing properly....do it yourself! I paid a fitter to fit these as it made sense to at the time, they fitted them "on the wonk". So had them removed and had a fresh set to hand if anything broke. Sadly the gutters broke.
£300 for the pair.
I have created a repair that is almost OEM, creates a full watertight seal and increases the hight of the original gully by about 0.2mm (so no issues with fitting flush to the bodyline). This is made from Black PETG Pro (Although its not dealing with any stresses or exposed to the elements so a non issue). These have been bonded to the window with CT1 black. I haven't got any photos of the finished article to hand but will add or send to anyone interested.
All previous adhesive has been completely cleaned up and they are ready for fitting (I would recommend a fresh coat of primer as some of this has been stripped off).
Collection or meet up and only looking to sell as the pair. Based in South West Kent.
Full details can be found on the Camper Glass website HERE.
The bit that broke.
The repair "patch", nothing fancy but ensures there is zero chance of the repair leaking.
£300 for the pair.
The bit that broke.
