Park assist module location
Bazgreener
Hi all,
can anyone advise where the park assist module is located on a 2017 T6? Got a sensor fault which appears to be a wiring issue.
many thanks
I believe it is below the steering wheel. Need to remove lower part of the dash. When my park assist was not working it turned out to be the buzzer fault which was also here. £7 part from Amazon and sorted, only problem is it’s a bit tight for space under there but doable.( Mines a 2018, with rear sensors only).
Just add, with yours being pre 2018, if it was anything to do with the buzzer defect, it probably has a second buzzer in the top part of the n/s b pillar.
Thanks for the info. :)
