Parking sensors on lowered vans
Blu-Tack
Is there a way to adjust the parking sensor's field of view?
Now that my van has been lowered the rear sensors could do with being raised a little. Reversing up to a driveway that had a relatively shallow incline set them off showing a collision.
I think they are set at a single trajectory, you may be able to mod where they fit so they point up a little but you would have to fill and smooth/paint the lower half and it would be a lot of work. You could try 3d printing an adaptor?
Just an idea, the sensors are held in place with plastic mounts that the sensors click into, these mounts are attached with a type of foam tape that's a couple mm thick, could you unstick the mounts and reattach with either an extra gap at the top or smaller gap at the bottom to adjust the angle slightly but retain there position within the bumper ??
