Hello. I'm currently installing some T6 power folding wing mirrors into my 2016 T6 Highline. The instructions are a little vague as to where I can tap into a permanent live and ignition live.
"4/The red ( permanent live ) & black(earth) from the module can beconnected behind the dashboard.A permanent live can be found behind the relay block just below the light switch. Earth can go to the metal work behind the dashboard or an earth point. The black/red with fuse is to be connected to an ignitionpositive. (the two thick yellow/black wires on the rear of light switch are ignition positives"
I've attached some pics from the instructions.
I've only ever used piggy back fuses and wired in some door spot lights before.
Any help direction is appreciated thanks.
