AMS12-12-30 | Ablemail
ISOLATION
Non-Isolated
1 2Volt nominal vehicle and solar supply (8-32V) ; USE 1 2V SOLAR PANELS
1 2V nominal Varied as required for battery charging programme
30A Continuous
<2mA @ 1 2V input
Output overload & over temperature protection with fully automatic reset
200mm flying leads of thin wall auto cable.
Wiring Connections:
Length: 250mm, Height: 46mm, Width: 1 24mm, 975g
Maximum 70ºC. Minimum -30ºC
E11 Approval-Immunity requirements UNECE regulation 1 0 issue 4 Which covers all
aspects of EN50489:201 0 & CE Approval-Immunity to requirements of EN61 204-3
OUTPUT LOAD CURRENT
DESCRIPTION :
PART NUMBER : AMS1 2-1 2-30
For Guidance on component size Installation & troubleshooting:
See Installation Instruction
Version: C
31/1 0/201 3
The product images shown are for illustration purposes only.
Ablemail Electronics reserves the right to change product images & specifications at any time without notice.
1 2V INPUT
1 2V INPUT
COMMON
1 2V OUTPUT
ALTERNATO
SOLAR
NEGATIVE
BATTERY+VE
RED
BROWN
BLACK
WHITE
CONTROL POSITIVE YELLOW
https://www.ablemail.co.uk/sites/default/files/specs/AMS12-12-30.pdf
It looks like 32v max solar and 30amp max through put for that ablemail.
