Pipe in sliding door?
tomosllyr
Took my sliding door panel off to fit some better insulation. Found a rubber pipe which seems anchored at the bottom but top part is loose. Is this meant to go anywhere?
It's not actually for the sliding window, it's normally attached to a catch 'tundish' for the door handle.
Without it, any water getting in via the door handle will be running down inside the door skin and collecting at the bottom of the door.
