It difficult to retrofit it in an OEM style as the buttons to turn them on and off are part of the AC dials so the whole AC control unit needs replacing and it all connects up via an external relay tucked away somewhere, it’s a great setup as it has low/med/high heat settings utilising the temp sensor but it’s costly and difficult to replicate
Hi all first post on here so take it easy I have a kombi high line 69 reg had a quick look under drivers seat and there are some wires are they used for heated seats and if so what’s the process for installing the heat pads as in would they plug into these wires then a switch on dash or is it more complex than that any advise would be great
