Possible to use OEM Microphone and DAB aerial via wiring harness?
Danksy
I'm setting about replacing the standard headunit with a Pioneer SPH-230DAB double din unit and ideally would like to use the OEM Mic and OEM DAB connectors rather than installing new ones. Is anyone aware of the part details for appropriate connectors that will do the job please?
My T6 doesn't have a MFSW or cruise (in case that's relevant),.
I couldn't easily see anything that would fit the bill!
Thanks very much
What radio did you have?
Have you got OEM Mic and OEM DAB connectors? What about GPS?
Got any pics? Of radio and conections?
For the dab you just need an adaptor, around a fiver off amazon.
For the mic, I looked into this, the oem one uses a different technology (can't remember the name now) long and short of it is you can't reuse it. I used the oem location for my kenwood mic that seems to work fine :thumbsup:
Quick Google, ones active and ones passive. That's the difference. You can get oem looking ones with a headphone jack on the end that might be better?
If I hadn't just put all the interior back I might be tempted to swap my kenwood one for an oem looking one to see if it sounds any better
@Dellmassive The standard headunit is the Composition Colour, running DAB.
I don't need GPS as I'm going to use carplay, so the only connnections I'm concerned about are the OEM DAB connector to the gold connector below,
The other thing I was trying to avoid was running a MIC to the OEM location (by using the original if possible - thanks @RedUn ) - The pionner connection I think is a 3.5mm jack. (see second pic below) 1615985416664.png
