Had to disconnect battery this morning when taking air bag off. On reconnecting power latching isn't working. Does it need any specific calibration like the leccy windows?
AFAIK there is no specific calibration like the window auto stop but might be worth taking the van for a short drive to let all the ECUs get their act together and see if you still have an issue.
If not pulling the fuse for the module and leaving it a day or so to fully discharge and then reconnecting can clear some faults.
Good news, the trick with a full electrics restart is not to panic until you've had a drive/give it a bit of time/ had a decent cuppa as things are often out of kilter as the modules have all powered up at different times and they are used to being on all the time and then just going to the low power sleep mode - essentially you rebooted the van and it takes a while for everything to settle down.
