Hello, I am searching for help here because we have a very mysterious pulling to the right.
At front the car have all new bunches expect subframe, but the subframe bolts are changed.
All springs and dampers are almost new. Inner and outer tie rod are changed.
The pulling problem came after flywheel, driveshaft and the gearbox splines (for the right driveshaft was changed.)
The pulling is there in all speed, also when reversing, it increases when braking. Have tested different tires without success. Only things that left is rear arm bushes and subframe bushes.
It was in the Volkswagen repair shop today without results, have been in 3 different shops for alignment at 6 times without good results.
Any ideas.
The car is VW T6 2018 2wd DSG 200000km on clock. From Finland.
Any ideas.
