Quest Atlantic 3 way chest fridge - £150 collected / summer camp
42L 3 way fridge ( Gas, 240vac, 12vdc )
Our Opinion:-
A very close copy of the Dometic RC1200 3 way chest fridge. Offering the same capacity and flexibility but at a more competitive price.
This is a fridge so will maintain an internal temperature.
The Quest Atlantic 3 way chest fridge offers the same 3 way operation. Operating off a Gas Cylinder, Propane or Butane (subject to purchasing a gas hose and regulator to suit the Gas Cylinder you intend to use). it has spark ignition & 3 settings. On 230v Electric via a 13Amp plug and by 12v DC by plugging into a cigarette type socket in your car. Remember like all camping/Caravan Fridges the Fridge will not cool if plugged directly into a 12v supply. There is no thermostat on the 12v circuit. It is only designed to maintain a temperature if the fridge has been pre-cooled on 230v or Gas operation. This is the same for all caravan Fridges.
A reliable 3 way chest fridge that will take 2L bottles standing up, and can make Ice with the supplied supplied cube tray. Works best on gas or 230v operation and will out perform any 12v/230v thermoelectric coolbox.
What the manufacturer says:-
A premium quality, large capacity chest fridge. This fridge is made from premium quality materials . It has a large 41 litre capacity and can be used in 3 different ways. It can be used with bottled gas, 12v (car cigarette lighter) or mains (240v) electric. It features a high quality piezo ignition system when used with bottled gas.
We recommend using only 100% propane, or 100% butane gas with this fridge. If you use LPG or any mixed gas the higher oil content in these gases can cause issues and your fridge will require more regular servicing.
It cools more than 25 degrees below the ambient temperature. It comes with ice cube trays and can easily fit multiple 2 litre bottles inside. It features a low noise absorption system so it runs quiet. Requires (not supplied) a hose and regulator before using with bottled gas.
Features
- Premium Quality.
- Piezo Ignition.
- Car, Mains and Gas Use.
- Large 41L Capacity.
- Cools more than 25 Degrees Below Ambient Temperature.
- Low Noise Absorption System.
- Runs Very Quiet.
- Complete with Ice Cube Trays.
- Gross Capacity: 41 L.
- Weight: 16 kg.
- Size: 50 x 51 x 44 cm.
- DC Cooling: 85 Watts.
- AC Cooling: 85 Watts.
- Energy consumption (24h):
- AC: 1.6 kWh/24h
- DC: 169 Ah/24h
- Gas: 100% Propane or 100% Butane is recommended
- Gas pressure: 28 - 37 mbar
- Gas consumption (g/h): 10.5 g/h
Important Information
We always recommend using 100% propane or 100% butane gas. If you use LPG or any mixed gas the higher oil content in these gases can cause issues and your fridge will require more regular servicing.
