Quick battery charging question..
Teesix
I need to charge my starter battery. Do I need to disconnect the terminals first, or can I just turn the charger on with everything connected?
Thanks.
Connect your positive lead to battery positive and connect your negative cable to a good earth point and you’re good to go.
John.
What he said...
Because of the power shunt sensor in the battery NEG terminal.
A battery specialist advised me that if you have a vehicle with a smart alternator it’s a good idea to put an external charge on every couple of months to prolong battery life. At the moment my solar is keeping it at 100%.
