mlacar182
Hello,
First Sory for Google Translate from English.
I have VW T6 California and need some help in changing the main unit.
Van come with radio composition audio, then I find new radio composition media (5K7035200D).
I mounted radio in the van (needs new adapter and antennae), radio works ok. BT also works,
Only micro and USB are missing (composition audio have integrated microphone and USB in the spark unit). Radio has been disabled for a function (not activated). Then VW service activated, works fine, but BT does not work
no more. Ok, Mic is missing.
What type of microphone do I need to order and how to connect it to the unit?
Also USB device does not work, decoding is required?
I connect this USB to radio:
USB unit: 510 035 726
Data cable to USB: 000 098 602
App connect is not enabled.
Thank you for your support.
