The station logos help you to easily find the station you want to listen to.
DAB/Radio station logos are manually copied over to a spare SDcard you have (not the maps sdcard):
Radio Station logos for your infotainment system.
It is even easier to find your favourite station with the right logo. A wealth of original broadcaster logos, which you can install on your radio or navigation system (composition media, Discovermedia, Discover Pro), can be downloaded here as a ZIP file.
The link below offers you the channel logos for Great Britain in ZIP format. The logos are only provided for use in Volkswagen Radio systems (composition media, Discovermedia, Discover Pro). No other use is permitted.
Download Great Britain radio station logos.zip
How to install the logos on your system:
1. Simply save the file to a directory of your choice with a click on the link below.
2. Unzip the zip file and search for the relevant logos.
3. Copy this to an SD card.
4. Then, connect the storage medium to your infotainment system.
5. Now you can import the desired logos into your device.
6. To do this, tap the Setup button and then tap Sender logos.
7. Now tap the desired station button to which a logo is to be assigned.
8. Select the source on which you saved the image (e.g., SD1) and select the logo.
9. Repeat this process for other logos, and return to the main radio menu by pressing the radio button.
10. The SD card can then be removed.
EDIT: credit:
@Hinsley
Thought I'd try to fill some of the missing radio logos in DAB and FM.
Downloaded the latest set from T6Forum and VW and merged the two but still had gaps. Googled it hoping to find something with all of them but nothing seemed to have a full up to date logos.
I did find this site that lets you search and download VW friendly logos!
Find your favourite stations
To find a logo for your favourite radio station...
- Search for the station (using the search at the top-right of this page).
- Scroll down to the bottom of the page
- You'll find a link marked "Get a logo for your VW car radio"
This page will give you a correctly-sized logo, named in a sensible way to help you. You'll also find full details of how to get that logo onto your car radio.
Radio stations in the UK
