Been driving my self half mad……trying to cure a low rumble/rattle from my sliding door …I had @Absolut5 replace rotten door cards they even thought it could be door alignment….so took the plunge and used white Lithuim grease ( WD40 spray type )..on all metal parts even sprayed the electric door shut connector ( pushed in and sprayed the sides ) and roller guides….well It worked ….( I was using Dry Silicone spray ) I’m now so happy
ps we also suffered from the dreading sliding window leak ( hence door card change…van even smells better ) so rather than replace the windows we sealed the gap with a waterproof flexible sealant….ok can’t use sliders…but in the last 5 years never did open them…so Will for once have a dry van ……Cheap easy fix……I was going to fit 2 new THQ sliding widows @£400 + fitting
so ……
happy
so ……
