Rear Bumper Excessive Flex / Movement
Hi, I picked up a T6 that’s had a camper conversion and the top of the rear bumper is very flexible. You can literally push down on it and moves by about an inch scythe while of the back of the bumper. As you can see from the picture it’s had a tow bar fitted and I’ve read that often clips are snapped in the process. Can anyone advise on what parts I need to order before I take the bumper off. Any images or links to part numbers would be great. Thanks in advance!IMG_7025.jpeg
You are probably missing the polystyrene padding blocks that support the top of the bumper.
This thread should help:
Pete
Yeh, the towbar fitting has caused that. ... No filler piece been fitted.
That’s great, thanks. Am I right in thinking that they come in singles and you have to fit two?
Also, when I push down on the bumper beneath where the two doors meet in the middle I can see two cut outs. I’ve noticed some posts referring to clips for the top edge of the back bumper. Is this just at the sides and the filler piece sits in these cut outs? Thanks in advance!
