hi, anyone know if there is a way of getting the camera to stay on however fast you reverse. The faster you go the camera turns off, just when you need it!
Andy.
Andy.
That’s a new one on me, never experienced it. At what speed does it switch off?hi, anyone know if there is a way of getting the camera to stay on however fast you reverse. The faster you go the camera turns off, just when you need it!
Andy.
Just checking another VW forum, its set to work up to 10kph and it is adjustable via VCDS. Just got to find out how!’That’s a new one on me, never experienced it. At what speed does it switch off?
I’ll have a look at that when I get chance, I must be a steady driverJust checking another VW forum, its set to work up to 10kph and it is adjustable via VCDS. Just got to find out how!’
Didn't work for me . The adaptation channel adjusts only speed forward when parking sensors are disabled - or can be activated with the button. The allowed max value is 20 km/h.Interesting...
Indeed there is in module 10 an adaptation channel "MAS02042-Deactivation limitation" set to 15km/h from the factory.
I have been thinking it's for disabling parking sensors when going forward. Never thought about reversing but have noticed that "vehicle speed" on the bus is always ≥ 0 even when reversing.
You just made me realise something, on one of my vans the camera stays on longer than the other so must be something different on each effecting it. Nothing to do with speed though, happens even without moving.If they are all controlled by the same parameter and you increased that, one side effect could be that the parking sensor/camera screen lingered for too long when you started going forward again which could be annoying?
When reversing the camera display turns off at 15 km/h. Have to say that before I didn't know that speedo works when reversing - never before looked into it when reversing - usually the reversing speed has not been the issue .
I don't know if that can be done. There is no obvious adaptation/coding for that.Can you make the front sensors active below speed without needing button press or reverse it’s stupid the way it works now
Tying up loose ends...Can you make the front sensors active below speed without needing button press or reverse it’s stupid the way it works now
