Rear fog light not working
simonblake75
Hi there. I have a 2016 T6 which I have recently had converted and a tow bar fitted. When I switched the fog light on, the warning bulb came on and the fog light isn't working. I've tested the the bulb housing and also the towbar pin with a multimeter and no volts are coming through. It went back to the conversion company today and they disconnected the towbar electrics and said the fog light wasn't working when they did the fitting (but someone forgot to pass that message on to us). They've tested the junction box under the passenger seat and confirmed no volts are coming through there either (to tray and prove it's nothing to do with the conversion). I can only assume it's a fault with a fuse, a relay fuse or the switch. Any ideas please? As I'm going mad! Attached is a pic of my fuseboard as I understand everyones is different!
