Rear optical parking no longer working following clutch/dual mass flywheel replacement
tintim
120,000 miles and still going
Need some help, just collected my van from the garage after having the slave, clutch and flywheel replaced. Everything was great until I selected reverse. The optical parking doesn't seem to be activating, no noise or visual on the discover media unit. Checked for fault codes, none... Is there a switch that the garage has forgotten to reconnect? Any help appreciated. Ta
Yeah I think you're right, I've tested the optical output on the head unit and both audio and visuals are there. I also double checked the gearbox setting as I've read if it's set incorrectly that can cause probs. Toggling breaks it it so its all correct. Back to the garage tomorrow then...
The resolution was a clip that hadn't been reconnected. Apparently easy to get to and a 5min fix. Everything working again :)
OT but related to the new clutch/dual mass flywheel and slave replacement.
No juddering when pulling away and no clutch slip in third. Van is buttery smooth :)
